Group: DynoMotion Message: 11359 From: Peter Tannoury Date: 4/12/2015
Subject: kmotioncnc M13/M14/M15 setup
Dear all. Is anyone tried to use and setup M13/M14 and M15 to control a second spindle control CW and CCW using KmotionCNC Setup screen
Group: DynoMotion Message: 11364 From: Tom Kerekes Date: 4/12/2015
Subject: Re: kmotioncnc M13/M14/M15 setup
Hi Peter,
M13,M14, and M15 are not defined in KMotionCNC.  But you could configure M103, M104, and M105 if you wish.
I think the overall most general approach is to treat dual/triple Spindles as if you had a Tool Changer and as if you were loading different Tools.  The "tool change" program in KFLOP can then set a global state (Virtual Bit or persist variable) in KFLOP to direct subsequent M3,M4,M5, and S actions to the appropriate device.  The Tool Table length and xy offsets can then be used to compensate for the second spindle.  There is also a ToolTableSet.c example that you might use to "touch off" each spindle and set the Tool Length for the current Spindle.
